Ok so I upgraded my rig but kept the same soundcard.
The sound output is now much quieter than before the upgrade, before at 40-50% volume the sound was loud, now at 100% is sort of normal level but not loud, its as if the amplifier isnt working or something.
Bit of googling suggests its a power problem on the card.
It was difficult to unplug the floppy power cable when dissasembling the old rig, but as far as I know I havent damaged the card. Its the same psu and floppy power connector been used now.
Any thoughts on this?
It is not just volume either with the headphones on the sound isnt quite as clear as well as not been as loud.
