XML Help
I'm not sure that will help me. The XML file I need the information from is not on my server so I cannot add a stylesheet to it. I can only link to the file.
you could use a server-side script to import the XML file from the website, then transform it on the server and dish it out as HTML. of course, this is more complicated, and there may be other soultions i'm not aware of.
XSLT on the Server
Ok, I've got this in an html file named blah.html:
Code:
<html>
<body>
'Load XML
set xml = Server.CreateObject("Microsoft.XMLDOM")
xml.async = false
xml.load(Server.MapPath("http://futureready.org/xml/?pid=bcTcB3tO"))
'Load XSL
set xsl = Server.CreateObject("Microsoft.XMLDOM")
xsl.async = false
xsl.load(Server.MapPath("blah.xsl"))
'Transform file
Response.Write(xml.transformNode(xsl))
</body>
</html>
and this in a .xsl file named blah.xls both files are in the same directory:
Code:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform"><xsl:template match="/">
  <html>
  <body>
<xsl:for-each select="statistics/school%20pid='bcTcB3tO'/votes">
<xsl:value-of select="total_votes" />
<xsl:value-of select="hottest" />
</xsl:for-each>
  </body>
  </html>
</xsl:template></xsl:stylesheet>
and it's coming up blank....any help?
Code:
xml.async = false
</body>
</html>
Server.MapPath only works with files loacted inside the web root folder. this would be fairly easy to do with PHP. I'll look around to see if ASP has a solution
