G'day all,
Does anyone own or had the chance to play with the Xigmatek Utgard? I'm thinking of getting it to replace my Antec Sonata III, which has developed a rattling side after 3 years of use and has never had brilliant airflow.
The reviews seem pretty good, but I'm just wondering what the build quality is like. Are the panels relatively solid and fit together nicely, or are they a bit flimsy? I remember reading a review on the Midgard which said it wasn't the best build quality, have they fixed this with the Utgard?
One thing I liked about the Sonata 3 was how solid it felt, though that hasn't stopped it developing a rattle I suppose (though it is 3 years old now). If the Utgard isn't solidly built I might just attack the Sonata with a dremel and try and fix the rattle and mod it so I can put a proper front fan in it and get some airflow, instead of the poorly positioned mounting holes it comes with standard.
