Xigmatek Elysium User Review.
Gorilla
First of all, this isn't exactly a professional review. I didn't measure system temperatures or fan noise. It's all pretty subjective.
So I got my Xigmatek Elysium a few days ago. I thought I'd share my thoughts and some photos. I was able to get it from newegg for $186.00 shipped thanks to some coupon stacking that probably shouldn't have happened. Newegg customer service made a mistake by telling me to order the case and use one coupon code and then contact them and they would refund me for the second coupon code that wouldn't stack. Thank god I saved that chat session. Believe it or not they weren't thrilled about honoring it, but eventually they did come through, so props to newegg.
I should also give a shout out to Xigmatek customer service. When I got my case, the box of parts had come lose from the twisty tie that held it in place inside of my case. I'm guessing this is what caused the 3 inch long scratch inside of the side window. Not something that thrilled me. However, I emailed Xigmatek support and got a response within an hour. A day later they asked for my address because they are shipping me a whole new side panel. They apparently don't want the old one back, which means I'm probably going to have to mod it at some point this summer. Anyway, I couldn't have asked for a better outcome.
So before the photos let me share a few thoughts. This is a really interesting case in that Xigmatek got so many things right, but also got some really obvious things wrong.
Also, keep in mind that the following list of cons aren't all that bad. It's enough to knock off 1 point out of 10 or so in terms of grading, maybe not even that much. However, I also suspect that some of these issues might be more important to some of you. For example, I know a lot of people really like a bunch of hot-swap bays. I personally could care less about hot swappable bays.
Cons
1. Annoying HDD mounting system. This case shares the drive by system that we have seen in cases like the Antec 900 and 1200. However, believe or not, the one in the Elysium is worse. The drive bays in the Antec cases have lips on the inside that you set the HDD on and then screw it into place. Well the Elysium doesn't have those lips. So you place your HDD in it and then have to try to keep it lined up with the screw holes while screwing in the screws. Installing my 3 HDDs and one SSD took longer than anything else in transferring my rig over.
2. Weird HDD mounting screws / mounting design. This relates to point number 1. The hdd bays have rubber grommets in the screw holes that suggest that it is meant to be a screwless design. I've seen some cases where the screws don't have threads, but instead just push through the rubber grommets and hold the hdd in place. This seems like what Xigmatek had in mind here, but they put threads on their hdd screws, which means that instead of just pushing into the side of the HDD, you have to actually screw it into place. It's just strange considering that they could have made things easier by not putting threads on the screws.
3. No SSD mounting options. Seriously, I had to go out and buy a a bracket to attach to the side of my SSD so that it was 3.5" wide. It's hard to believe that Xigmatek did this. I mean honestly, for a flagship case this is just incomprehensible. While there is a hot swappable drive slot on the I/O panel on top of the case, I don't want to have my main OS drive sticking out of the top of my case all the time.
4. No way to mount 3.5 devices in the 5.25" slots. Seriously Xigmatek? Even my old Antec 900 had an adapter so that I could mount a card reader in one of the 5.25" slots. Even worse, they don't include a front 5.25" slot cover with a cutout for 3.5" devices. So even if I get a bracket to mount my card reader in a 5.25" slot, it is going to have empty space all around it. This again is weird since even my crappy old Antec 900 came with one of these. Though this still isn't a huge deal since the only thing that I plan to install in one of the 5.25 slots is a fan controller.
A forum member mentioned how funny it would be to put an ITX board in this case, so I did.
Here you can see one of the HDD bays. Each bay holds up to 4 drives. You can see the rubber grommets that I mentioned previously. I should not that the middle two drives are not that difficult to mount, however, the top and bottom holes are very frustrating because those holes are located under a layer of metal. You can see what I mean.
Another shot of a drive bay. As you can see, there are no "lips" or anything to guide the HDD. So you have to try to line it up with the holes and then blindly try to screw the screws into place. Very frustrating.
Like I said, besides the top hot swappable bay, there is no SSD support here which certainly perplexes me. Last time I checked it was indeed 2011.It's stuff like that which makes me wonder if maybe I'm just missing parts. Anyway, as you can see I had to get a bracket for my SSD.
Shot with the front panel taken off. The front panel comes off without any trouble.
Just about done moving everything over. I still haven't ordered any water cooling stuff yet, but eventually I plan to throw a triple rad up top and a double on the bottom. I've heard that Xigmatek is supposed to release a mounting bracket so that you can mount a rad in the front. If I remove the unused drive bay I will have another 300mm for a rad there.
Side panel on.
Next to my desk on the stand that I built for it. Unfortunately my DVI cables aren't long enough to reach that far so I've had to move it onto my desk until I get some longer ones.
Side shot.
Powered on. The LEDs are actually white, not blue, and they look very nice. However, my camera really struggles in the dark, so this is the best that I could provide.
So, overall I really like this case. I've always wanted a lot of room and boy did I get it with this case. I personally really like the way it looks. The cable management is great. The only real down side to me is that the HDD mounting system is obnoxious, but then again I am pretty unlikely to move my drives again at this point. The fans look good (at least I really like white anyway) and move a decent amount of air. They are pretty quite as well. Xigmatek could have included more fans, but then again I plan on water cooling, so it doesn't really matter. Xigmatek Customer service has been great (assuming that they do follow through with sending me a new side panel).
One nice feature that I should point out is the fan power system. At the top and the bottom of the case there are spots to plug in up to 5 3pin fans, each point is power by a molex connector. So if you have a lot of fans and don't enough connections on your motherboard, you can connect up to 10 fans to these points. Additionally, Xigmatek includes a wire that lets you connect one connection point to the other so you only need to connect the first one to a molex connector. Additionally, there are several spots that you can mount these connectors on. It's a pretty nifty feature.
One thing that I wish that they had done differently would be the bottom of the case. There is room on the bottom of the case for a triple rad (120mm or 140mm, either will fit). However, because you can move the hdd bays anywhere you want, they could have extended the mesh on the bottom under the bays. If they had done that, I could move the drive bays up a couple slots, install the PSU on the top of the case, and then have room on the bottom for a quad rad and room on the top for a dual rad. Of course, i could always just mod the bottom of the case myself. It wouldn't matter how it looks since no one would ever see it. However, it is a shame that Xigmatek didn't think about this themselves because it would have made a great case that much better. I mean think about it, how many cases out there in this price range can support a quad radiator out of the box. This one could have, but doesn't.
So that's about it for now. I still have some cable management tweaks to work on. And of course there is still water cooling gear to order and install. Feel free to ask me any questions you might have. I'm happy to take photos if there is something you would like to see.
Update: 7/13/11 I got a whole new side panel from Xigmatek today. I had asked for just a replacement piece of acrylic to replace the scratched one but they sent me the entire thing including a 200mm fan. They didn't make me pay for shipping or anything. Bottom line is their customer service was great even if their English was not perfect.
I wasn't paying a lot of attention when I looked at that first picture, thought to myself "that is the biggest case I have ever seen, what the freak does he need that much space for???"
not a bad looking/functional case. light on bullshit bling which is always nice.
I hate how they took a case with clean lines and then messed it up with a fat old mesh on the side panel for a fan.
i bet that humungous side fan helps a lot, it'd help me with cfx im sure
Thanx for the review. I'm glad I stayed with the 650D.
Having the no-lip part for drives makes me scratch my head and wonder WTH was Xigmatek thinking and if it doesnt have SSD support, Thats a oversight IMHO.
Still not a bad looking case. I dont really care too much for the side window though.
I picked up one of these monsters yesterday at Micro Center in Dallas for about $230 w/tax. I've been looking for something to replace the TT Armor LCS I've been running for a little over 5 years (sans liquid cooling).
I've been scouring the web for the last couple of weeks or so trying to find a similar design -- full tower ventilated all the way down the front and with nice clean lines overall. I had been considering the Lian Li PC-X900 but had pretty much sold myself on the Corsair 700D, primarily because the price tag on the PC-X900 is a little ridiculous. There just aren't a lot of cases out there vented down the front that (in my humble opinion) have a nice clean look throughout.
When I laid eyes on the Elysium I said "oops, that's the one." Pretty much everything I've been looking for.
Holy. $(*@.
This thing is huge. Even though I played with it for a minute in the store I didn't realize how truly big it was until I got it home and (barely) slid it under my desk. it dwarfs my TT Armor, and I thought that was a big case.
This is a seriously big case. If you want something roomy to work in, this is the case for you. I haven't bought any other parts for my upcoming build but I'm going to order the power supply first and see how the cabling is going to shake out -- I think I'm going to need an extension or two.
After getting it home I suffered a little buyer's remorse. This isn't quite the high quality case I thought it was after checking it out at the store. For such a big case the cable management panel on the right hand side is quite shallow. The side panels are a big pain to take on and off -- they simply slide in and out like an old style traditional case -- no fancy release mechanisms or latches here -- and the thumb screws were on there very tightly -- it took quite a bit of pressure to get them to release, and they took a little paint with them on their way off.
The tool-less brackets for the 5.25 inch bays are pretty cheap and don't look that great. As JapaneseGorilla said the hard drive cages (although there are 2x4 bays, which is nice) don't have guide rails so it's a pain to slip a drive into the two middle slots. And no SSD bracket. The slip cover to reveal the top USB ports/audio jacks is cheap plastic and not very attractive. Also, the two USB 3 ports on the top have traditional USB plugs so installing them to a header on your mobo is out.
And finally, I hate the window. I really hate it. Just a personal preference there, of course. And nothing i can't fix with some power tools and a little effort.
And did i mention it's so much bigger than I realized?
Ok, so all those down points aside, at the end of the day I'm still looking forward to building my next rig inside this behemoth. I do like the overall look of the case. The built in cable management is going to make life a lot easier and save me from drilling any holes. The idea I have going in my head for the side window I think is going to be great, and I shouldn't ever have to worry about this bad boy ever overheating.
Japanese, thanks for the review!
With all my whining about side windows and how much I hate them, you make it look pretty good! I have a few questions:
1. HDD bays... do the rubber grommets cut down on vibration of the hard disks? No review i've seen has addressed this and most of the gamers who have this already only use SSDs or like, a single platter HD. I have 6 HDDs in my system with my raid array.. vibration noise reduction is important!
2. You got an ODD in the top bay - most of the reviews said this was impossible because it would damage the cables coming from the top hot swap bay and USB ports. Did you have to crush your cables to get your top optical drive in there, or did xigmatek do a last minute fix?
3. I gotta say it was hilarious seeing the itx board in there. Nicely done!
4. Your fan controller - how did you work that in with the built in xigmatek controller boards, if at all?
5. A few other people with this case actually double-sided taped their SSDs behind the motherboard tray, lol. I've seen pics of it and it looks pretty rad. Others taped theirs to the side of one of the HDD cages too.
6. One last question about cabling - Curious as to whether my 4+4 pin +12V cable will reach all the way to the top of the case... did you have to use an extender?
Thanks in advance man, great review!
1. I to be honest, I don't know if the rubber grommets cut down vibration or not. I know that Xigmatek claims that they do, but I've never actually noticed hdd vibration, so it's tough to know if it's been reduced.
2. It was a little bit tough to get the top ODD in there, but it wasn't a huge problem. Yes, it did hit the wires, but they basically just pushed out of the way. I don't think I'm hurting anything by mashing them up there.
4. At the moment I just have a little single fan Gelid fan controller that I use for my cpu fan. I haven't really used the built in fan power boards other than for the case fans that came with it, and those are quiet enough that I don't need a fan controller for them. I have wondered if it is possible to use a fan controller to control the second board, because that is powered with a 3 pin connector from the first board (which is powered by a molex connector). I might mess around with it later. Ultimately I'll just got a normal fan controller when I water cool.
5. Yeah, I considered doing that, but because I have 3 HDD and 1 SSD and each drive bay holds 4 drives, there wasn't really anything to be gained by sticking the SSD behind the motherboard tray. I suppose I could have hidden 1 sata cable, but that's not a huge deal.
6. I did use an extender, but I didn't need to use one. The cables on my Antec TP 750 New are pretty long. I just used a NZXT individually sleeved cable extender because I think it looks better.
Good review.
Question though - how good are those fan filters? They don't seem very high quality judging by the other reviews I've seen.
Also, is there a fan filter for the side panel? It seems a bit odd to put filters for the front, top, and bottom without having a filter for the side intake.
Good review.
The fan filters are decent, but not super great. They are basically just strips of fine mesh. They will get the job done for the most part though they might miss the finest particles. There is no filter on the side panel. With the way that they designed the side panel it would be impossible to put a filter on it without requiring you to remove the 200mm fan every time you wanted to clean the filter off. So I guess they just decided that it would be easier to not put a filter on the side.
Good review.
There is not a side fan filter that i know of on it, Jap will be more know.
Curious question, Where does your name stem from hyper?
Okay; ty.
My name? Uh, I just kind of made it up. Hyperion is one of the Greek titans.
Just wanted to post an update. I got an entire new side panel from Xigmatek today. It even has the 200mm fan on it. Scratch free this time :D.
Anyway, big thumbs up to Xigmatek support. Nice to find another company that takes care of their customers.
whatd it do to your temps?
Honestly, I can't really say. The weather really heated up here around the time that I got my Elysium (from mid 60's to mid 80's). I don't have AC so system temperatures went up, but because it's hot outside. My guess is that temperatures are probably about the same coming from my antec 900. The front fans don't move as much air as the antec tri-cool fans on high, but they produce a fraction of the noise (Seriously, my 900 setup sounded like a vacuum cleaner; part of that was the tri-cool fans, and part was the cpu fan which now has a fan controller on it so it is much quieter). Even though the front panel fans don't move as much air, the 200mm side fan probably more than compensates for that (I couldn't use a side panel fan on the 900 because it would hit the heat pipes on my cpu heatsink, thankfully the elysium is wide enough that I don't have that problem).
Regardless, I plan on getting into water cooling in the coming months.
Haha, I know that my response probably doesn't help that much. Basically the air flow in this case is fairly good. At the same time, it's pretty clear that they expect a lot of purchasers of the Elysium to water cool so they don't provide a ton of fans. Then again, I don't know that more fans would have made a difference. I would also guess that the sheer size of the interior probably helps to dissipate some heat.
Just one more bit of advice. This is probably super obvious to the rest of you. This case is not ideal for carrying to LANs. haha. While I did get a ton of compliments on my case, I also had to worry about my arms giving out and my whole system falling to the ground as I carried around a building. So basically, if you hadn't already figured it out, this case is massively large and heavy. lol
How is this case in comparison to the HAF 932?
Well, you are going to have to look at the actual specifics of each case. I haven't ever owned a HAF case so I can't give a direct comparison. From what I know of the 932 (I considered buying a 932 or a HAF X before I got this case) the main difference is size (as is common to pretty much any other case out there). The Elysium is several inches longer and taller than the 932. It has a few more pci slots, more drive bays, etc. Additionally, you can get more and larger radiators into the elysium.
I went with the elysium because I wanted size and I really liked the looks of it. I mean, it was made with the SR-2 in mind, but even though I'm using a normal ATX MB I still love all of the room that it provides.
I'm happy to answer any specific questions you have about it, but again, without having ever possessed a 932 I can't really give you an exact rundown. I will tell you that I have no regrets getting this case, though to be fair I paid less than the current price which sort of affects my judgment.
