Xigmatek Casings Enquiry
erik8hfr
I've a hard time of choosing between Xigmatek Asgard 382 and Xigmatek Midgard II. Which one should I go for?
Is it regret that I chose 382 instead of 381? Because I think 381 has better air intake compared to 382 due to front panel design.
The front panel on the 382 doesn't have any fans. But it is open, so air will be able to access through the front.
I honestly dont think you will have any problems with over heating.
Do you have a Budget? And does it have to be Xigmatek?
Should I change my Xigmatek Asgard 382 to Cooler Master Elite 311 Plus because of top exhaust so that I can avoid hearing interior sound?
In my opinion, when your dealing with case's in that price bracket... the quality from case to case wont vary too much.
The thing is can I avoid hearing the parts sound inside the case after I change to Cooler Master Elite 311 Plus due to non-top exhaust?
I have a Asgard II for my wife's computer and it is OK... materials are thin and cheap... i.e you have to be careful when working with it but it has held up ok since it doesn't get moved around or abused.
but it isn't that great of a case...it is what it is a cheap case... which is what those two Xigmatek cases you are looking at look like to me.
what about the BitFenix Merc Alpha?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811345014
