XFX HD 5870 $189 AR
Ovreel
Link
Good deal, makes me wish I had waited a couple months instead of getting my Sapphire 5870 that I had to RMA :p
Looks like a good deal, but before I bite...what's the difference between the 5 and 6 series? (5870 vs 6950)
Power consumption? Heat? Etc?
Stock 5870 uses slight more power than stock 6950, ~2 watts idle and ~15 watts load. The XFX's cooler is markedly quieter than the blower on the regular one and keeps it ~6-8 C cooler the reviews I've read, and it uses 3+1 phase drMOS. Overall it's a good change from the reference 5870, so if I was in the market and there was no tax in CA I'd jump on it.
Thanks, looks like I'll save my self some money and get this instead of the XFX 6950 as they seam very comparable.
What about future driver releases? Might aid to the 6950. Also you can't change the voltage on this 5870 if overclocking. Good price thou.
With the 5000 series you can force refresh rates in OpenGL and DX 10/11 titles using Powerstrip, with the 6000 series you can't. One thing to consider if you are a CRT user.
Something I forgot to mention, since this may not be common knowledge, The HD 6950 2GB reference models can unlock their shaders and overclock to usually reach the stock 6970 in performance. So you do get a big step up in performance for going with the 6950. The 6900 series also supports EQAA which is similar to nVIDIA's CSAA, it doesn't use video memory and uses much less resources to apply AA.
Either way, if you are willing to spend $250 you can get the 6950, or $190 and get the 5870. Both are good buys.
AMD will continue updating the 5870 drivers long past its useful life. Products become legacy products based on the DX version supported and even the legacy products get infrequent updates. This is a great deal and if my 4870X2 wasn't still up to the task I would hop on this.
I have this card and while I havn't really tried to OC it, it's given me no issues to speak of. Quite, cool and reliable, plus it's XFX so good resale value.
At times like this, I wish the laws at work would conspire to make Newegg's facility in CA explode in a large ball of flames.
In CA, the total price after using the $10 coupon is ~$230 :(.
EDIT: Also, in my first post I made a mistake. This card has 4 phase drMOS and 1 regular phase for the memory. Without voltage control, I've seen it hit ~950MHz in the reviews. EDIT2: To be clear, the Black Edition cards have been reviewed by ~5 sites, and of the three that overclocked the card, they all got >=950MHz.
Agreed. I wish amazon would match this deal.
plus rebate :)
Very tempted, even though I'm in CA... ~200AR, which is a decent price. But yeah, AMZN would be great...
deals like this make me continue regretting not getting the $199 5890 eyefinity6 a week or two ago.
This is priced about right. Not quite enough to get me to bite.
