XFX HD-585X-ZAFC boot problem.
Hey guys...
Just got my SB build going and was playing BFBC2 for about an hour when my computer locked up. I powered it down and back on but the video never came back and the system does not sound like it is loading windows. The ASUS P8P67 Pro that I am using has a red VGA led next to the card that lights up with the XFX plugged in. I am using my old 8600 GTS and it is working fine. Anyone have any ideas what the problem could be?
System
i5 2500K
ASUS P8P67
G Skill Sniper 8G DDR3 1600
XFX HD-585X-ZAFC
Antec Earthwatts 500
WD Black Caviar 1TB
Windows 7 Pro 64bit
It could be the PSU, but I think you may just have a bad card. Perhaps you could exchange it with Newegg.
Thank you.
Would a too weak power supply allow the card to run for a while and then cause the non-boot? The PSU has two 6 pin connectors. Just wonderin' if I just need to get a new PSU. Have already got the RMA # for the card.
Thank you.
I'm not really sure how an inadequate PSU would affect your computer.
I think you should try booting again with the 5850 and perhaps running Furmak. If that fails, then you know the card may be faulty.
