Hey guys in new here so go easy on me
I have read so much over the last few days on problems similar to mine i think my brain may explode. So please help me out
I built myself a new rig the other day and got an xfx gtx280 to compliment the components inside. Now I have built many machines in the past and actually work with pcs for a living but my experience with higher end components is limited as its only standard machines and components I use on a daily basis.
Now apologies if this confuses you but I'm going to try explain my problem as best as I can via writing.
The machine runs so sweet its untrue however the gfx card makes a TINY buzzing noise when under load (ONLY in games or 3dmark06 etc) After doing some research i have seen that others have similar issues and its just a case of a coil or cap on the card that makes the noise and it is not uncommon in high end cards (8800gtx ultras, gtx 260s and 280's etc). Its definitely not the PSU (as others on the Internet have suggested) as I have changed it already because my previous one made a terrible noise when under load anyway. So I went from the tagan pipe rock 700W to a cooler master m850 and the noise from that part has now gone.) (for those interested my PSU was suffering from the exact same problem as this chap: http://uk.youtube.com/watch?v=uZkwNXoeOeY)
It doesn't bother me to much that the card makes this noise as it is practically inaudible. However I get the same noise interference in game though my headset and others get a buzzing when I talk in ventrilo. (Only while in game if I alt tab to desktop the noise goes, for both them and me? I hope your managing to keep up) However this only occurs though the front panel audio on my case. If I plug my mic into the rear jacks on the sound card the noise vanishes.
Is it possible for the front audio cable in my case (antec 900) to pick up this electronic noise interference?
It certainly is a strange one and I just wondered if you could shed any light on it at all?
Rig is listed below:
Processor: Intel(R) Core(TM)2 Duo CPU E8600 @ 3.33GHz (2 CPUs), ~3.3GHz
Memory: 4094MB RAM (Dominator DDR2 1066)
Hard Drive: 320 GB SATA II Primary HDD, 160GB SATA Secondary
Video Card: NVIDIA GeForce GTX 280 1GB GDDR3
Monitor: 17 Inch TFT
Sound Card: Supreme FX Audio Card (Factory Card for the striker II Forumla)
Speakers/Headphones: Black Icemat Siberia Headset
Keyboard: Razer Tarantula Keyboard
Mouse: Logitech G5 Lazer Mouse
Mouse Surface: S&S Steel Mouse Mat
Power Supply: CoolerMaster Real Power M850 Modular 850W
Operating System: Windows Vista Ultimate X64 Bit (6.0, Build 6001) Service Pack 1 (6001.vistasp1_gdr.080917-1612)
Motherboard: Asus Striker 2 Formula 780i chipset
Computer Case: Antec 900
Its just the audio interference that is really bothering me i understand that high end cards can buzz as suggested all over the internet but through the sound ports too?
