XFX GTX 260-Tigerdirect
crazyboy515
LINK
mine didn't come with a backplate and came in a small box (like a shoebox). GPUz shows that i have a 55mm,but i read somewhere that GPUz Older versions shows that it has a 65mm
does not having a backplate help the heat better? and what is the dff between 55m and 65m?
Mine fits the same description and I believe they are 55nm. 55nm cards are supposed to run cooler and draw a little less power.
55nm cards dont have the backplate....
both of mine are 65nm and i love the backplates, it makes them look more stealthy in a case with everything else black.
also i dont think you can use the voltage tuner programs with 55nm, only 65nm.
