xfx 7950 DD overclocking foes
Scotoe
Can only get it to 950 core 1400 mem. Can't seem to increase the voltage via Afterburner, the slider is grayed out. Any ideas or alternate solutions?
Hmm, maybe no support has yet been added for this? if anything give it some time. On that note 950/1400 is pretty good going from the stock clocks :p
I agree. I've just seen this card oc'ed to 1050 core after adjusting the voltage using afterburner. Makes me wonder if it is more a driver issue at this point. I can get it too 1050 core 1500 mem with no artifacts or bsod, but the driver crashes.
you have to use the newest beta12, and unlock voltage control
earlier betas don't support 7900 series...
BOOM! Solved. Running @ 1050 core 1400 mem stable. Could go higher, but stopped there. Thanks all.
Might as well go higher. I have the regular BE and it runs perfect with sliders maxed out in CCC with no artifacts in games.
Oh, I had the wrong version of afterburner.
I just might have to push it. :D
What type of voltages are you having to run with your card, Scotoe? I am running into the same problem of stability at 950 mhz core clock.
I upped it to 1.093 and have had zero issues. Gonna try for max oc tonight tho. stock on mine was .993
got it to 1100 core 1500 mem, @1.093 v, but had some artifacts in bf3. Dropped it back to 1050 core and they disappeared. Would upping the voltage help with the artifacts or does that seem like my limit? Temps are very good where I am at now.
