GregTombstone
- Mar 6, 2004
HI Got a biostar I45 tpower running a quad and at present a HD6570. Win 8.1 pro 64 bit
Installed a new XFX R7850 and booted. Screen displayed boot splash screen for 5 seconds or so as normal and then went blank. Machine seemed to continued to boot as the hard drive light was working away.
My PSU is 500 watt but I had to use a 6 pin pci express adapter to give power to card. There is a 4 pin molex power connector on mb but i have never plugged power into as i assumed you dont need to since card has pci express power.
I put old card back in and its running fine. so any Ideas?
1/ should XFX run on the existing catalyst driver until I un-install same and reinstall latest with mantle. Should I have removed drivers with old card in and then swap cards and boot again in vga, install new driver etc.
2/ do I need to use the graphics power connector on MB as well as the PCI express power connector.
Hope you can help BF4 awaits !!!
