XFX 6970 & AC Xtreme Plus II installation.
Cyane
Hello,
Just wondering if anybody has any experience with the Accelero Xtreme on the Radeon 6900 series cards (more specifically, the XFX 6970). I've read quite a few horror stories regarding people shorting out their cards or over tightening the screws, etc. I bought the new Accelero Xtreme Plus II but I'm a bit hesitant to install it with concerns of damaging my card. Can anyone offer some advice / precautions?
Thanks in advance.
Cheers!
the cards that got damaged were 5970s, and it would break a dvi port if you overtightened some screws in the back.
I personally use an accelero on my non reference 5870 (that was a joy to fit) and it works great.
