XFX 6950 2GB Fan issue...
Reklaimer
Been having my 6950 since December of last year and recently i've noticed my temperatures getting higher and higher as the months go by. I have two Dell ST2410's (crappy, i know) and i'm using hybrid crossfire with my onboard graphics for my second monitor. Playing BF3 my temps get up to 86 degrees celcius. I do know that anything under 90 degrees is ok but its uncomfortable to see it get that high! I notice under the AMD Control Center that my fan only goes up to 50% usage and never gets higher than that. I can, however manually set my fan to spin higher, but its not variable. How can i get my fan to go over 50% usage?
did you clean you card's fan? some compressed air will do the job.
you can install MSI Afterburner, go on Settings, Fan, Enable user defined ... and you can set the Fan speed X Temperature.
I use mine:
30%/40C
40%/60C
70%/75C
100%/85C
with this settings my graphics cads go up to 80C (top one) and 74C (botton one), If I leave automatic it goes up to 86C the top one. (with overclock, without overclock you can take 5C out)
I use mine:
30%/40C
40%/60C
70%/75C
100%/85C
Do you have to have an MSI motherboard to be able to use Afterburner? I'm not at home right now, but i'll give it a try when i get back.
I also have an XFX 6950 2GB card -- I'm assuming yours is the non reference model like mine?
If so - they run hot even with the fans at full tilt. I'm crossfired with a 6970 (reference cooler) and it's temps are ALWAYS about 25-30C lower than the XFX non reference cooler. this is all running stock speed as well (800MHz)
My XFX usually tops out at 100C (while bitcoin mining) even with the fans going 100% and 3 external case fans moving air across it. I've even gone so far as to remove and re-install the heat sink to make sure contact was good.
I can't wait for winter to get here -- I'm in North Texas, and our days are usually 90F-110F till October.
I'm in South Louisiana! Almost neighbors...i probably get a bit more humidity than you :)
Wow yeah I've got 4 case fans total. So i was stumped when my card would get that hot. So i took Drangueos' advice and installed MSI Afterburner, set it to boot at startup and changed my fan/temp settings and i now can play BF3 for hours with full loads at temps of 70-75 degrees. A difference of about 10 degrees give or take, but i am MUCH more comfortable now with that temperature than one almost approaching 90 degrees. Also, i tend to keep my case extremely neat and as dust-free as possible, my case comes with dust covers, not to say that dust can't find its way in, but i blow it out every few months or so.
Thanks for everyones help!
