Are you on crack? You must be missing something.lloose said:http://www.newegg.com/Product/Product.asp?Item=N82E16814150106
Even a good quality 6600gt would be a much better buy AND still a huge step up from your 6200.
tsuehpsyde said:Are you on crack? You must be missing something.
6600GT 128-bit memory interface, 8 pipes and 4 shaders
6800NU 256-bit memory interface, 12 pipes unlockable to 16 and 5 shaders unlockable to 6
Even a shitty no-name 6800 would out perform even a top-of-the-line 6600GT. Not by much, but your logic is terribly flawed, sir.
Don't listen to these jokers that've probably never owned either of these cards. That 6800 for $144 is a killer card with headroom to overclock higher and unlock extra hardware components for extra power per-clock. XFX, while I don't like them, aren't nearly as bad as these people are saying. What personal proof do any of you have against XFX? I seriously doubt any of you have any.
Double Jesus said:i say go for it, i have a 6600gt xfx and it's a great card! [H] gave xfx a good review a while back as well.
also are the pci-e versions of the 6800 unlockable? how bout the 256mb versions? and can you do 2 in sli?
thanks.
chameleoneel said:no the pcie versions are not unlockable. but you can get 256mb versions which is nice, and the pcie version of the 6800 core tends to overclock a bit better, and yes you can run them in sli, thats what i doso, no you can't unlock pipes, but its made up for a bit by option to have 256mb of ram, possibly better overclocks, and sli. 6800's are no slouch and even one will do you fine for awhile, my ahtlon xp system made short work of the fear demo with an agp 6800.
geckoman said:considering buying the xfx 6800 from newegg to replace my evga 6200 ... i want it for playing bf2... thoughts on this card?
