XFX 5870 doesn't support voltage control?
man. doesnt matter just make sure its a reference card from what ever company you buy from.
Hahah well I've screwed myself here, got the non adjustable ones. :(
You can still overclock, but you just can't adjust the voltages. I wouldn't worry about it too much. The 5870 is still an amazing card, and if you have 2 in Crossfire you'll be set for quite a while. ;)
I bought a reference one that I priced matched to a new revision (also cheaper!) one :)
