Sorry for the long post...
I got fed up with the noise from the stock cooler of the 4890, so I decided, after a lot of research, to purchase an accelero twin turbo. From everything I've read, people claim that this heat sink works quite well.
A lot of people who have the accelero + 4890 leave the red, stock heat sink on and mount the accelero over it. This is because the stock heat sink is actually used on the memory AND VRM's
However, there seems to be different versions of the 4890, and I can't seem to find anyone with my particular version (or im not looking hard enough). Anyway, my stock heat sink does not cover the vrms... but it came with a thin black one mounted on. My 4890 is a ZDFC version.
With the super loud stock heat sink, when I bench crysis warhead, the VRM's are in the low 90's c. Now with the accelero, i've got a major decrease in GPU temp (15-20c cooler),but the VRM's peak at 115c...
I've tried mounting the heatsinks that came with the Accelero, but that gave the same temps. I run @ 100% fan speed for the accelero and it doesn't help that much for the VRMs. This is definitely a problem, right? No artifacting goes on, and my system is completely stable, its just a really high temp... Any ideas?
Thanks [H].
Thanks [H].
