JoeKillaMofo
- May 12, 2011
Anyone know of an in-depth setup primer for an advanced File System newbie? That only sounds a little contradictory right? After much Googling I have come across a number of different sites but none address and explain the issue in full, some hit on it only slightly while others only go into smaller specific details...
Basically I am looking for a primer that goes (quickly) through the setup theory (general do's and don'ts) and then some overall stripe alignment and then ideally goes into the specifics of it (logging settings), possibly even some common scenario's (raid controllers, some OS specifics, etc).
Having very little experience with it combined with the info on it being somewhat sparse and just a little cryptic I am finding setting up an optimized XFS system to be quite the challenge.
TL;DR: XFS omg help pls! wat is a stripe!?!
J
J
