so far i've hit a stable 3.61GHz with my xeon x3440. (190 bclk, 19x multiplier)
a picture is worth a thousand words, though.
so what do you think of the temps? 20 passes of ITB at a stress level of high and i managed to average 61.75C across all four cores. i certainly could've pushed this chip farther, but i'd like to improve my cooling just a bit before i do. i'm using 1.25 vcore at the moment, at least that's what it's set to in my bios. cpu-z is reporting a lower 1.232 for some reason. i think once i add a few more case fans as well as a second fan on my hyper 212+ for a push/pull config, i should be able to bump up to around 3.8GHz. i suppose i could even try 4.0, but i want to ultimately settle in at a more realistic/safe number as i'll be running this machine just about 24/7.
