Xeon Mobo Question
Originally posted by Tyklfe
I'm totally open to sugestion - It just seems that the only Mobo's I can find with PCI-X are Dualies....
Also, can anyone comment on weather or not it matters to run Dualies without ECC?
You'd do well to take a good long look at Iwill's DPI533... Not a single PCI-X in sight! Also, you can't actually run this board with registered DIMMs! ;)
The other board you really should take a look at is Asus' PC-DL Deluxe... Good features and uses the i875P chipset instead of E7505 that the rest of the Xeon boards do.
