bcracer220
- Dec 7, 2006
hey guys
i need ur help!
i have a xeon 3060 632a and its prime stable at 3.4 with 1.33 volts (real) for 13 hours... the problem is the freaking temps, im running a big typhoon on it and the idle temps are 46 c for one core and 49 for the other. then under load it hit 65 C in orthos (it does stay stable though despite those temps (13 hours small fft), ALSO BOTH SURFACES ARE LAPPED to 1500 grit. i was thinking it might be the thermal paste cuz its this no name stuff, so should i go in for a new thermal paste? i tried re-seating it many times and this is the best i could do.
should i get new thermal paste?
http://www.svc.com/as5-3g.html
any other ideas?
i need ur help!
any other ideas?
