XenApp/Desktop Question
ciscokid454
I am going through the process of building out a Citrix VDI lab environment and having some trouble understanding one basic piece of the puzzle.
I have a XenServer and ESXi 5 virtual infrastructure, and failing to figure out where you create the virtual machine for the Master image. (whether for MCS or PVS)
Any help here, would be greatly appreciated. Thanks
Citrix has documentation on how to use XenDesktop with ESXi. We set it up as a POC and it worked well
The documentation doesn't state the specifics to the creation of the default VM to use for the Master Image. It says something to the effect of create the Windows 7 virtual machine then create the master image.
I have figured it out though, (I think I already knew it, just wasn't thinking appropriately about it).
Thanks for the help!
