This case was def worth the money! The fan is of good quality, and the added speed controller and on/off switch on the side is great. At max speed you hear the fan a little bit but turn the nob just a tad and its silent! The inside is your basic case, no real wire routing advantages. Though there are Air holes on the top of the case, the backside of the case (the one the motherboard is on) and of coarse in the front by hard drives. For adding fans you have the option for 2 90mm on the back and either a 120 or 90 in the front. If you want to go crazy on air flow i believe it would be possible to drill some holes and put a fan on the top of the case by where the air vents are. All in all this case is worth the 80 bucks i think newegg has it for now. Enjoy
(ps this is my first review)
Inside the beast
First power up
The 36cm fan.... can some one say ultimate cooling?
THE CASE! (tad blurry)
Inside the beast
First power up
