Xcilo(aplus) El diablo
Krilikz
Ok this baby is planned to come out sometime this month, right in time for my system build. Only thing is im trying to determine what heat sink i should buy for my quad core to fit in this case.
http://www.heise.de/newsticker/meldung/86701
I know people with the twin engine case could only fit something as tall as zalman 9500. Any suggestions on what i should do?
That is quite possibly the worst looking case I have ever seen.
Get the Thermalright Ultra extreme 120 if it will fit, if not the CM Geminii while completely over the top is quite good.
Edit: No sorry, I had forgot about the Vento for a minute there. Second worst case.
what cause would you recommend, i dont see anything wrong with this one.
i like that case. cool fans too, i second the Geminii, or the scythe ninja if it will fit.
How much is it?
Arcygenical, to be fair you can't only compare it to gaming cases. I saw one of the older versions of this in a shop a while back, I had a quick look just for the sake of it and the door fell off :eek:
Depending on the price point I can probably thing of a lot of better case (looks wise is of course only an opinion) but in build quality they are much better. I just found the old version for £65 so the new one might be £5 more. £70 can get some really nice cases.
£50-£90
Akasa Eclipse
Lian Li A05
Lian Li PC7+II
Silverstone TJ05
CoolerMaster Mystique
Antec 900
NZXT Adamas
Hell, I just got a Lian Li v1200+ for the same price as that.
Hey, That reminds me, have you all seen the previews fo rthe new Transformaers movie coming out in July?
yea its cause its from the same company.....and only this one has a 36cm fan...not a small 25 cm one lol
I have the Clio 380 and I like it a lot..... now a 360 fan on the side OMG. I love it xxxxx:eek:
You'll probably have to buy the case and then take measurements to determine what size hsf you cab get inside it. Unless the company comes out with a list of hsf that does work no one knows at this time. Waiting for a good review may take awhile. Hard to say.
Forgetting size for the moment you may not need a hsf. You may only need to get something like a Scythe or Tuniq that has a heatsink only. No fan. Those two big fans may be enough of themselves so that you can go fanless on the heatsink and have a really quiet setup. It really depends on the cooling effectiveness of the case fans.
If that were my case I would paint the inside flat black because the window is so big.
Cool front design. I'd let it eat crackers in bed. ;)
Geminii is a POS
It matches stuff like the ninja while being low profile... kinda what he needs with the silly fan on the side of the case no?
