xBox360 vs my specs..
Travisrd
Me and a friend were arguing, friend says his xbox 360 is better than my specs i didnt wanna argue cause i really wasnt sure :(
My specs are in my signature, i'd really like to know! :D hehe, much appriciated
-travisrd
your computer is better cause you can do more than play 360 games on it.
you have better specs anyway. 1 more core doesnt mean shit, when the games out only use 1 anyway.
but the 360 was always intended to just play games, its like trying to compare apples to oranges.
Your computer has the better specs, but the 360 will have better performance in game.
It doesn't have to run windows and numerous other windows related processes in the background while trying to play and the 360 games are made specifically for that console.
QFT
Your computer does indeed have better specs. The chip used in the Xbox 360 is probably only a little more powerful than a 7600GT. Still, awesome graphics can be had on it since only one platform has to be written for (allowing for more optimized code) and it doesn't have to run Windows and all that junk.
search for porn on your PC, and then tell you friend to search for porn on his Xbox360
the state the obvious again, it's like comparing apples to oranges.
I read somewhere the RAM runs at 700mhz on a 128-bit interface, not too impressive.
Consoles can generally do a lot more with the hardware they have, since they aren't upgraded and need to stay competitive for several years. Devs also don't have to worry about making their games work for varying systems.
OTOH, your comp can probably play a wider variety of games, and do a thousand other things the 360 can't. And you can OC it.
