Xbox360 & Media Center Remote Problems
p0lish
I just purchased a Logitech Harmony One to control all of my equipment. I have a Media Center PC with this remote and IR receiver.
http://www.newegg.com/Product/Produ...re=media_center_remote-_-80-101-003-_-Product
I also have an older Xbox360(120gig HDMI), and they seem to respond to some of the same remote codes. When I have an activity to turn on my media center, my Xbox always turns on and goes to the Media Center. Is there a way to change the remote codes for my media center, and then change them on the harmony remote? Or change the codes on the xbox?
Anyone have a similar problem?
Thanks,
-p0lish
There is a setting on the Xbox to tell it to only listen to the Xbox 360 remote control.
Ran into this myself.
yep saw this last night...
the other way to get around it is to use a RF remote and use IR blasters that are addressable over each component....
