JBark said:On a fixed pixel display(LCD/DLP), a digital connection (like DVI or HDMI) running at the display's native resolution is more than likely going to be your best bet. Less D-A and A-D conversions lead to a better quality signal. Whether this translates into a picture quality difference you can actually see depends on all sorts of factors.
In the analog world, it's likely to be VGA>Component>SVideo>Composite. Individual results may vary, but most of the time this will be the case. It's the simple fact that more wires usually means a better picture, since you can transmit more discreet amounts of information on each wire. VGA and component will probably look very similar, but the other 2 will have quite noticable quality differences on almost any display.
VGA - 5 signal wires
Component - 3 signal wires
SVideo - 2 signal wires
Composite - 1 signal wire
In your specific case, I would imagine that VGA would look the best. I'm really hoping the X360 comes with a DVI/HDMI output, though I doubt it will. I don't know if it would look much better than VGA, but at least I could guarantee 1 to 1 pixel mapping on my 1280x720 projector.
mentok1982 said:Component is better than VGA or DVI.
I think HDMI is even better than component.
Arkanian said:So far Microsoft has only shown that the VGA adapter will only be available at launch. I wonder if a Digital Connection is at all possible then. I would figure that they would have a HDMI/DVI cable if the console had a Digital Output at launch. So my guess is that because of this, there will never be a HDMI/DVI cable ever for the Xbox360 unless they make the connection Digital in the future which is VERY possible since they will be upgrading to HD-DVD in future Xbox 360 machines. It is very AWESOME that they are offering a VGA adapter as it is so that everyone can experience Xbox360 in High Def.
supposedly the rumors that have gone around,the video encoder in the 360 supports it just its not as of right now going to be an accessory for the consoleJBark said:From what I've seen, the video output chip on the X360 supports analog only, so it's very unlikely we'll get HDMI/DVI. But hey, a man can dream.
And yes, both BluRay and HD-DVD require an HDCP HDMI/DVI connection to display anything above 480p. So whenever the x360 gets one of those drives, we'll get a digital connection. But who knows when (if ever) that will happen. I might have to borrow/rent a PS3 when it comes out, just to see what the digital output looks like vs. component.
HDMI is just DVI with audio connectors......no extra bandwith video wiseDraax said:HDMI > DVI > VGA > Component
I don't make the rules, thats the way it is. I am almost positive the only difference between DVI and HDMI is that HDMI has increased band width and surround sound as part of the connection.
paranoia4422 said:HDMI is just DVI with audio connectors......no extra bandwith video wise
Staples said:It doesn't matter because few TVs have VGA input. So you WILL use component.
peacetilence said:there are VGA to DVI adapters are there not?
no,DVI-I can be adapted to VGA because it includes an analog signal,in order to take a VGA signal to digital you need a converter not an adapterTetrahedron said:yes there are
paranoia4422 said:no,DVI-I can be adapted to VGA because it includes an analog signal,in order to take a VGA signal to digital you need a converter not an adapter
* DVI-D (digital only)
* DVI-A (analog only)
* DVI-I (digital and analog)
HDMI = DVI > VGA > Component > S-Video > CompositeDraax said:HDMI > DVI > VGA > Component
Shorty said:HDMI = DVI > VGA > Component > S-Video > Composite
Video Quality, they are equal.Draax said:If you have the choice between HDMI and DVI, you should always chose HDMI, that way 5.1 sound is routed through the same cable, which leads to less cable clutter.
So HDMI > DVI
So HDMI > DVI
bwhahaTetrahedron said:yeah but my sound doesnt go into my TV (projector) it goes to my receiver.. defeating the purpose of HDMI.
Yep....most TV's with HDMI have optical out so that you can hook it to your receiver. But yeah I see your point because almost everyone with HDTV's will probably have a receiver so it does defeat the purpose.Tetrahedron said:yeah but my sound doesnt go into my TV (projector) it goes to my receiver.. defeating the purpose of HDMI.
Shapeshifter said:Vga is better then component, Vga offers a true RGB colour connection, while component does not.
Maichena said:That's what I thought too but Wikipedia seems to suggest otherwise.
Check it out at: HDMI Explanation
It comes in 2 flavors, Type A and B and also includes Digital Content Protection (Should have seen that coming)
Draax said:If you have a ghetto reciever that doesn't support HDMI switching, yes I guess you would have to route the audio seperate.
If you are going to spend upwards of 3K on a TV, I would think you would match it with a high quality reciever, ... but thats just me.
Archaea said:I have a Denon AVR-5700...and I have a Panasonic PTL-500U projector. 1280x720 (720P native res) So I meet your criteria - yet I don't have a ghetto receiver just because it doesn't support HDMI switching...
There are a lot of incredible recievers that are more than a couple years old that would not support HDMI switching because HDMI is a 2 year old technology.
For the rest of you folk...
DVI > Component....I've done the A/B test in my own home - with expensive component cables, and expensive DVI cable.
DVI is much sharper and since HDMI is the exact same standard with audio out and a overall smaller connector HDMI > Component....while DVI = HDMI.
Tetrahedron said:a ghetto... lol
I have a Sanyo Z3 720p HD Front Projector.. my screen is 108inches.. much bigger than a 3k TV.. go figure a HDTV projector is better then a plasma or dlp tv set.. hmmm
so explain to me how I should hook my video (HDMI) to my projector and get sound to my 5.1 Onkyo speaker system without routing the sound to the receiver?
