Xbox Through The Computer
fu5i0n
Does anyone know of the program that i use to run my xbox through the computer???
i want to use the s-video connector on my video card also i dont have a tv tuner card.
cheers
cheers
There is no such program because you have a hardware issue that must be resolved first, and the s-video port on your videocard is no help because it is signal-out only.
You need a way of getting the signal into the PC, and that takes tv tuner hardware... Either a videocard like the ATI AIW series, or a separate device that works via USB or PCI. I would suggest a USB device like this one...
http://www.hauppage.com/pages/products/data_pvrusb2.html
USB devices are handy because USB will be around a LONG time, so you won't have to worry about the device becoming obosolete any time soon.
If his video card has VIVO, it'll work fine. A commonly suggested program for viewing full screen through vivo is Dscaler.
EDIT: lets get some specs on your pc so we know if you have VIVO or not.
