Xbox Slim
tw0_f0ur_
Here are some pics. Got bored with my slim. I took out my 3rd and 4th contorller ports becuase I never used them. Put a XLCD in there. Epoxy around the LCD. Painted the inside of my Xecuter Pro Switch. Looks very nice. Look foward to see Painting, Usb mods, Jewel mods, and more.
Then I Bonded in my XLCD and cleared my jewel :)
Then I started to paint after I sanded down the bondo.
First coat.
Second Coat
How are you going to drive that display/what kind of info can you dump to it from the xbox?
/not in the know
thought this was your base coat rite???
if not...what colour will it be?
/not in the know
I think he tried to sell this in the forums a while ago. He is using an x3 modchip to play games off the hard drive and to drive the screen if I remember. As far as putting games on the thrid party dashboards you use with the mod chips allow you to ftp into the xbox which means you can just use ftp to drop a game on the hd. Looks interesting so far but I would have left the extra controller ports but o well if you don't need them....
yes i did try to sell this on the forums awhile ago. I thought I would post my worklog. Im gonna update it soon with new pics. Somhting for ya'll to read. BTW i sold it for 250$
IMO the 1st xbox case if the most fugly design ever conceived. MS have been better taking the contents out of it and putting them in a cornflakes box.
Props to you for making it a bit prettier!
Just FYI that was a horrible bondo job. Use a bondo spreader next time. It'll make your life easier not having to sand so much.
Yea, It was my first time using bondo. Im gettign the xbox back tomrrow. I liked it to much that I wanted it back haha. So expect more pics tomrrow
I got my xbox back and it needed some work. I took off the LCD and the faceplate. Sanded everthing back down to normal. Fixed up some area's. Here are some pics. Expect some soon within the Hour.
(Sorry for the burry pics. My camera on wrong settings)
Put the bondo on..
but then after sanding it the Epoxy cracked. Time to re-glue and re-bondo. :-/
Update:
Finished the Front Panel. Bondo came out Really Well.
Now Im going to start on the top cover for the Xbox.
Here are two picture of it now. Im going to re-sand it and bondo some of the cracks and smooth everything out agian. I should have it done by tomrrow for the LAN party my friends and I are hosting. :)
Check back soon for more updates.
the LCD really doesnt do anything, But if you have XBMC (Xbox Media Center) It displays what file your are playing and how long it is and time untill completed.
