Xbox Power Supply!
CRASHFIRE
Hey all,
You probably saw this post in another area. I am placing here too because I really need the help. I am in Iraq right now. I had my wife send me my Xbox and the transformer I have blew the power supply. Has anyone here bought a third party dual voltage power supply off the internet? Or, has anyone bought a new power supply for their Xbox at all. If so, please let me know how it worked and where you got it. Thanks for the help. :)
At the back of the power supply there's a fuse, depending on the version it'll either be a round little sucker or a tube like one.
Look for 15amp 250volts (should say it on the fuse itself), this fuse is soldered on the board, so you'll have to remove it and replace it with an inline fuse holder and fuse.
I used an inline fuse holder and a 15amp 250volt fuse from radioshack.
here's an article on it.
http://www.xbox-scene.com/articles/powersupply-fuse.php
