Xbox Files To PC, How to?
TheBlueChanell
Ok, I was a Morrowind nut on the xbox, and put at least 500 hours into that game. I am going to be selling my xbox, to fund my rig, Is there anyway I could get my xbox file to my pc, so I could continue on pc where I left off on xbox. This way I can download mod's and have to restart the game, I was so far. Pretty Much done, which is why I want Mods.
Hmm, the xbox files aren't compatable with the PC version. So, I guess the short answer would be "no, you cannot use the files on the PC."
However, you can still transfer your files to you PC via memory card if you don't have a mod chip. However, they'd only be useful on the xbox version of the game.
I was afraid so, I just remember reading somewhere, you can convert xbox files, and use them on your pc.
I wouldnt give up so easy. I would seriously take a look at the file format on the xbx before. I know that a lot of developers doing cross development tools made many of the fies the same. Worst case scenario would be to manually hax the xbox files to a format that the PC reads by looking at the txt in the saves. It could be very tedious, but perhaps do-able...check it out.
M
The xbox uses a totally different type of file system, but it doesn't hurt to back that up, in case someone comes out with a port or something that will convert the savegames or what not....I mean comeon I uploaded video files from games on the xbox, and there is a program that will convert them to avi....it was cool. So dont give up, they might have something out there already....try this place and ask them Linky
