I got an xbox that was out of warranty from a friend which i'm currently modding. I have already changed the thermal paste, but now I want to quiet these damn fans by removing them completely out of the system.
I'm looking do something like this:
This fan is only for example. Currently the xbox 360 60mm fans move roughly 22-24 cfm per fan I believe. I would try to pull out a fan that is around 30 cfm to quiet the noise and move hopefully the similar amount of air due to the closeness of the fan to the heatsink.
What I'm worried about is if this would be an effective solution or would replacing the two fans with some other 60mm or the after-market cooling fans made for the xbox 360 be a better thing to do. What do you think?
I haven't seen one person do this thus far, more so with 120mm fans and removing the dvd drive to an external one.
Any ideas?
Thanks.
Any ideas?
Thanks.
