Xbox controller on PC playing UT2004 problems
MAXPower1812
I recently made a connector so i can use my xbox controller on pc. Im using the code underground drivers and all the buttons do work in the game controller properties page (in windows xp). Now when i play Unreal Tournament 2004, the first (left side) analog stick does what its supposed to do, without me changing any settings. It moves forward and back and strafes left/right.
Now my problem lies with the second analog stick. I want it to look up/down and turn left/right, just like the default controls for Halo (on xbox). After mucho messing around with the User.ini file, I was able to get the joystick to look up and down (Axis aLookUp SpeedBase=100.0 DeadZone=0.4) and turn left/right (Axis aBaseX SpeedBase=150.0 DeadZone=0.4), but they wont work AT THE SAME TIME. Now im thinking maybe there is some kind of conflict with the joystick being used as look and turn, but that really doesnt make any sense. They work fine individually, just not together. Anyone have any ideas on how to fix this? Perhaps i am using the wrong command?
