XBOX 360 with 4 games
Dano5
I have a friend at work that is trying to sell his 360. He bought at the end of Feb 08. Not very old. Call of Duty 4, Rainbow6 Vegas 2, Dirt, 2008 World series of Poker. Transformers game is in the pictutre but he sol it seperatly.
He is asking 470. Shipped.
If interested please IM me.
Looking at the manufacture date, which seems to say 2008, not 2007... it is probably a good bet that this is a Falcon not a Zephyr chip.
Manufactured on or after 8/24/07(An HDMI Premium manufactured on 8/19 has been reported as 65nm.)
You can also check the PSU brick, if it is 175w not 203w that is also a way to tell. You can also check Xbox 360 Forums which gives several methods to check your Xbox for the Falcon chip.
Looking at the manufacture date, which seems to say 2008, not 2007... it is probably a good bet that this is a Falcon not a Zephyr chip. You can also check the PSU brick, if it is 175w not 203w that is also a way to tell. You can also check Xbox 360 Forums which gives several methods to check your Xbox for the Falcon chip.
Yeah, its most likely a falcon. But you can't really go by the powerbrick since there are reports that the 203w (which is backwards compatible to the falcon), was still being shipped with the falcons. But if the brick is a 175w then for sure its a Falcon. I'm also reading that you cannot go by what the box lable says either because some boxes were saying 203w but would have a 175w brick making it a falcon.
Here is a pretty good registry where you might be able to match up the date and team to find out if you have it. http://www.360drives.com/list
