Xbox 360 Wireless Network Adapter $69.99
mo_money
Xbox 360 Wireless Network Adapter seamlessly synchronizes with the Xbox 360 system to enhance your Xbox 360 experience in the digital home. You can easily transfer videos and music from your Media Center PC, chat with your friends, play games via Xbox Live, and much more.
Features
Wireless A/B/G home network-compatible: The Xbox 360 Wireless Network Adapter is highly versatile and supports 802.11b, 802.11g and 802.11a (Dual band 5 GHz and 2.4 GHz).
Nothing to plug in: The Xbox 360 Wireless Network Adapter is powered by your Xbox 360 gaming console, so theres no external power adapter to plug in.
Stream photos and music from your PC: You can stream photos and music from Microsoft Windows XP and recorded TV, movies, and videos from your Microsoft Windows XP Media Center based PC.
Connects to other Xbox 360 wireless accessories: It collaborates easily with Xbox 360 authentic wireless accessories for worry-free integration.
Tech Specs
Manufacturer Microsoft Corporation
Host Interface USB
Manufacturer Part Number B4B-00009
Additional Information
Powered by Xbox 360 to eliminate adapter clutter
Radio collaboration with Xbox 360 wireless controllers for worry-free integration
Manufacturer Website Address www.microsoft.com
ISM Band Yes
Brand Name Microsoft
UNII Band Yes
Certifications & Standards
IEEE 802.11a
IEEE 802.11b
IEEE 802.11g
ISM Maximum Frequency 2.4 GHz
Product Name Xbox 360 Wireless Networking Adapter
UNII Maximum Frequency 5 GHz
Number of Antennas 1
Product Type Wi-Fi Adapter
Wireless Transmission Speed 54 Mbps
Transmission Speed Details 54 Mbps Auto-fallback IEEE 802.11a/g
6 Mbps IEEE 802.11a/g
11 Mbps Auto-fallback IEEE 802.11b/g
1 Mbps IEEE 802.11b/g
http://www.buy.com/prod/xbox-360-wi...ft-xbox-360-wireless/q/loc/108/201975281.html
or the MN-740 which is what I use.. and prefer since I'm very far away from my AP. I have both the MN740 and that one and the MN740 works better because I can position it where ever I want.
So this works flawlessly for you with the 360?
Works fine with no security or WEP. If you're using WPA (and I hope you are), it's a no-go last I heard.
yeah... it only works with WEP or no sec... The placement of my 360 forces me to use the MN740, I guess. I use a WRT54G and the Xbox 360 WIreless adapter won't hold a connection so that's why I use the MN740 w/ WEP.
So what does one go with if they have a long range(other side of house, up one floor) between the xbox360 and AP?
And I would prefer to use WPA2...
Not to rain on anybodys parade, but there are WAY cheaper ways to do this... http://i.gizmodo.com/5133447/how-to-add-wi+fi-to-your-xbox-360-smartly-and-cheaply
Picked up a cheap (~$30) WRT54G, flashed it with Tomato firmware, set it to Wireless Ethernet Bridge mode and your all done. Not to mention you get 4 ports to plug wired stuff in to and you aren't limited to just using the Xbox with it. I have all the devices in my entertainment center that have Ethernet ports plugged into mine.
I can attest to this... maybe not as "easier" to implement, but a far better solution.
Can I stream HD (1080p/720p wmv or mp4) from my PC using this??
No, you'll drop every third frame or so streaming over wireless which will be very choppy. If you want to stream HD content then you need to wire the xbox to the network.
Its a good solution, but not as mobile. Its more to carry to a friends house and once you get their you will need a pc to change your settings.
