Xbox 360 to PC help
secretjade
Ok, Im trying to find my PC through the 360. Here's the problem.. The network begins in the basement from a Fios modem. I split everything from there ie, one out goes to the living room, one to the office and so on. When you come into the office, it goes into another linksy wirelesss N router and then to the computer. Is the problem going through two routers? I want to keep the wireless N because of its range. What setup can I do to get to the 360 from the computer and keep the N?
Is the 360 connected to your network over wireless or wired? If it's wired, and the wireless N is running as a router and not an access point, then yes, that's your problem.
Switch the second router to Access Point mode and you should be all set.
