XBOX(360) Mods?
bob_the_frog
Aside from firmware are there any other mods that can be done to XBOX-360's ?
Just curious.
yea know that site quite well. More curious about modchips and/or boot hacks similar to those for the regular xbox. Seems accessing the HD of an xbox is pretty easy using a PC now just hacking the dashboard!
thanks anyhow
Best Mod Ever K?
All you need to do on the 360 is Hax the Firmware on the DVD Drive, not hard to do and if you use Google you can figure it out for urself
