Xbox 360 mod project help
jvz555
Hey i work on 360's and i just wanted to expand my customers, so i am going to mod one really really great and probably sell it and see how it goes so i can make more like that.
Here is how i wanted it to look but with colors :p
I am getting most of the stuff off here since i can find it cheap :D!
I am going to cut off the back of it so i can fit it a 2x120mm radiator on the back of the 360 with 2 120mm exhausting, possibly yate loons since they are silent but soldier a few green leds on them. I am going to paint the case black and install a clear side windows, then cut out part of the dvd drive top and install side view plastic as well and paint the drive itself black. i was going to use a XSPC Xbox 360 CPU/GPU Waterblock
and i was going to put some green water cooling liquid as well as green leds so in my mind it will looks pretty cool.
Now i was just looking for some advice as what parts to use etc. and how this design is. Any advice is good and comments and yes even jokes allowed :D
Edit: i also have a 7" lcd Tft 16:9 monitor ima use and probably make it swivel somehoq not sure yet where to put it though, but i do know i need some extra power, and i myself really dont know about PSU's so i need some help with that as well.
How about Antec Tricool 120mm fans with green leds for the rad. they have speed controls built in so they can be flexible based on need.
For the loop get som UV reactive green coolant and instead of green led inside go for UV. It'll be like:
If you use green led and green fluid it'll just wash it out. This way it'll pop.
Yeah i was thinking that for the fluid and the Antec fans are a better idea thanks :)
That's an amazing idea, I would love to do that. For the PSU it's going to be hard since the PSU for the Xbox is tiny. Maybe a micro ATX PSU would work? Could you get the measurements of the inside? I mean I have taken quite a few apart, but I never measured the inside.
well it should be pretty roomy since usually what take up a lot of the room is the air duct, but here is a pic and this is the one im going to use
