Xbox 360: Horizontal or Verticle?
Discussion in 'Console Gaming & Acc.' started by Diablo2K, Mar 16, 2007.
Verticle or Horizontal
Poll closed Mar 23, 2007.
  1. Verticle
    38.9%
  2. Horizontal
    61.1%
  1. Diablo2K
    Diablo2K [H]ardness Supreme
    6,599
    Aug 10, 2000
    I just got a Xbox 360 and was wondering what position you have yours in and why?
    I have always seen pics online of the Xbox 360 in a verticle position, but to me this seems kinda of an add way to position it. When it is verticle it is more prone to being knocked over or even off its stand. Also it seems it is also alot harder to get disks in and out of the tray. So why is it always pictured online in the verticle position?
  2. MrSneis
    MrSneis 2[H]4U
    2,555
    Apr 5, 2006
    I like verticle but it always scares me to have discs fall down while loading/unloading a new dvd. Horizontal is preferred if space permits!
  3. Syphon Filter
    Syphon Filter 2[H]4U
    2,595
    Dec 19, 2003
    Ditto.
  4. kelbear
    kelbear [H]ard|Gawd
    1,579
    Jun 22, 2005
    Disc tray has a scooped underside when it stands vertically, the discs can't fall unless you drop them yourself, never had any worries about disc dropping. Standing vertical has a smaller footprint, providing more desk space. The xbox360 is heavy, and has no practical risk of falling since the only thing that goes by that area are my fingertips. It's far more likely to die because I'm playing on it than to die because of moving.
  5. The Donut
    The Donut 2[H]4U
    3,086
    Jan 28, 2003
    I prefer horizontal as I find it quieter that way.
  6. Voltron
    Voltron Limp Gawd
    137
    Mar 9, 2006
    Good Poll! I have been curious about this as well.
    For me, I can only run it in verticle because of where it is placed. I would have it horizontal if I could just because it's easier to put the disk in.
  7. joemama
    joemama [H]ardForum Junkie
    9,576
    Sep 13, 2000
    Mine is horizontal on a shelf underneath my computer desk. Even though the console was designed to stand up..this seems more natural because gravity does it's job with the game disks and the vent holes on the "bottom" are free to breathe. Never had a problem with mine this way..
  8. SpeedRunner
    SpeedRunner Guest
    I like mine vertical, but putting disks in sideways seemed strange at first.
  9. CopyThat
    CopyThat Gawd
    708
    Oct 26, 2000
    Mine is hoizontal, on top of the DVD Player.
  10. Domingo
    Domingo [H]ard as it Gets
    17,163
    Jul 30, 2004
    I keep all of my systems horizontal. I've got everything set-up in an entertainment center/TV stand, so it just makes more sense for me.
  11. Sabrewulf165
    Sabrewulf165 2[H]4U
    2,947
    Jun 23, 2004
    <insert xbox/women horizontal joke>
  12. Rocketpig
    Rocketpig [H]ard|Gawd
    1,427
    Jan 6, 2004
    I had my 360 horizontal until last night when I bought a Pelican fan stand. I have the 360 in an entertainment center and while I tried to keep it as open as possible, it was still worrying the shit out of me. That box was heating up badly.
    So I put it vertical in a bigger area of the entertainment center with the Pelican stand. That should help it.
  13. KaosDG
    KaosDG [H]ardForum Junkie
    11,944
    Apr 3, 2000
    I have mine vertical
  14. 4saken
    4saken [H]ardForum Junkie
    10,839
    Sep 14, 2004
    horizontal.
    just feels safer to me that way.
  15. zero002021
    zero002021 [H]ard|Gawd
    1,317
    Dec 29, 2004
    Horizontal. Feels safer and looks better.
  16. RancidWAnnaRIot
    RancidWAnnaRIot EspantaPajaros
    11,039
    Feb 19, 2004
    Horizontal..
    just look at it.. it was meant to be horizontal.. if you look at all the writting on it.. it's all written such that you can read it whe nit's horizontal.. therefore i know they enigneered it for horizontal operation :D
    i like horizontal... more vents are exposed in the horizontal mode.. so i think it cools better liek that as well
  17. RancidWAnnaRIot
    11,039
    Feb 19, 2004
    trust me.. they ain't horizontal ;)
  18. o0akoni0o
    o0akoni0o [H]ard|Gawd
    1,301
    Aug 31, 2004
    horizontal, feels safer and with the way it is in my setup vertical just wouldn't work.
  19. morpheus6d9
    morpheus6d9 [H]ard|Gawd
    1,219
    Mar 11, 2005
    horizontal
    vertical is prone to scratching the disc
  20. tskiller
    tskiller [H]ard|Gawd
    1,075
    Nov 16, 2005
    Vertical. Its behind my LCD monitor so i dont have room for horizontal.
  21. Erasmus354
    Erasmus354 [H]ardForum Junkie
    9,394
    Mar 12, 2004
    Microsoft warns in the manual that while in the vertical position the Xbox 360 could maim or seriously injure small children or babies by falling down on top of them. (seriously, its in there, go check)
  22. TeamStrykerCore
    TeamStrykerCore [H]ard|Gawd
    1,439
    Sep 21, 2005
    I had mine horizontal, but then switched it to vertical
    If you check when its in the horizontal. The small rubber pads, don't leave
    enough room for heat to escape.
    I found out with the vertical it allows for better air flow and less surface area
    *on the bottom* covered by something else to let heat escape.
    I wish there was a survey showing if xbox 360's brick more if they are in the horizontal.
    The only bad part about the vertical is like everyone else is saying. It works great, i'm just afraid that one day because of how the drive was engineered I'm going to get scratches / gouges on my game disc.
  23. RancidWAnnaRIot
    11,039
    Feb 19, 2004
    in the vertical position you cover a lot of vent holes.. in the horizonal.. you don't cover so many though
  24. aznbumbaclot
    aznbumbaclot Gawd
    801
    Jan 14, 2006
  25. Symon14
    Symon14 Limp Gawd
    335
    Jun 18, 2006
    Horizontal. Vertical has a much higher chance of scratching your discs if moved while spinning.
  26. PWMK2
    PWMK2 2[H]4U
    3,032
    Dec 4, 2005
    Horizontal. The cabinet I have mine in used to hold my original Xbox, so when I configured the shelves, it was made for a horizontal unit.
  27. Diablo2K
    6,599
    Aug 10, 2000
    I am sorry to say that I agree with almost all the comments made so far. lol, I am serious, i can see the +'s and -'s to both. After reading this i started looking closer at the xbox 360 itself.
    my Xbox has been sitting with the power off in the horizontal position for about 6 hours sense I played it last. I stood it up on its end and I can feel heat coming out the side panel (which was on the bottom.) remind you this was with the power OFF! Theres no heat coming out of the Top (which was on the side with it in the horizontal position). theres a big differance in the amount of heat coming from these vents. what scares me about this is that with the Xbox in the Horizontal position these bottom vents do not have any clearance between tham and the table its sitting on, just not much room for heat to escape form the vents. I have not paid any attention to how much heat it makes when playing a game, but if can tell the differnace with it powered off I am sure it makes a big differance with it on.
    Hmmmmm, I just got an idea, Why not use a Lap Top Cooler and place it under your horizontal Xbox to help keep it cool. You know, the ones that look like a cookie sheet with fans mounted in it. Maybe even mod it so the fans on one side blow in and the other side they blow out, to help with the natural cross flow of the air.
  28. TeamStrykerCore
    1,439
    Sep 21, 2005
    I was thinking myself, of keeping my 360 in the vertical position,
    but... making 4 separate corner supports to lift it up a little bit off of the surface.
    It's just that I feel that more surface area is still covered in the horizontal and doesnt dissipate heat as quickly even though im covering some vent holes in the vertical.
