Xbox 360 HD DVD Player
Nvidia101
I got a used xbox 360 player but it Did not come with USB cable hookup ? anyone know what the name of it is and where to get it?
Check the PDF manual at xbox.com - should give you a definitive answer.
just use a standard one without a filter on it. i needed a longer one and i suffered no loss of quality using another cable.
It has a mini connector though for the part that goes directly into the drive itself if I remember correctly. Other than that it just a standard USB cable.
yes it has a mini connector at the other end. But exactly which cable is it. I googled it but came empty...
I hope your hd dvd player works well for you. Mine is crapping out. It will randomly decide to play hd dvds one day, then not work the next day. If I put in a regular dvd in there, it'll play that too. But lately, it has stopped reading dvds also... =\
Anyone else having this damn problem? Pisses me off cuz I can't watch my movies. :(
