I would have thought that was a given?BizKit123 said:So your saying next gen PC, will look better than a PS3 or 360?
bad example IMO, that game had a serious problem of consolitis, it was horribly optimized for PC. but i get what you are saying, getting such old harware like that to spit out some incredible gfx has to take incredible genious on the devs part. it must be easier to fine tune on Consoles rather than PC's or somethingkabob983 said:The benefit of consoles though is that when a game is designed around it they tend to be able to do alot more with their hardware than a similar PC. Example, a 700 MHz Xbox running Halo better than a 1.5+ GHz computer with more powerful CPU, more RAM, better video card, etc.
I wonder if there's a way to firmware update to DX10 though...not sure how that would work.
If you bought a "cutting edge" computer the same day a console launched the console would outlast it by threefold or more probably.
independantvariable said:Owell 1 year and its already obsolete, time for the trash with you xboxy
But maybe "elements" of DirectX 10 would be integrated into the Xbox 360 environment.Since I believe the direct x on the xbox is kind of a mix all around.
PWMK2 said:DirectX 9 came out a year after Xbox, but that didn't make it obsolete (it runs on DirectX 8).
kabob983 said:If you bought a "cutting edge" computer the same day a console launched the console would outlast it by threefold or more probably.
CodeX said:If by "outlast" you mean remain the same crappy graphics while the PC platform continues to constantly improve than I guess you are right, though thats kind of a stupid way to look at it.
kabob983 said:That's actually not what I'm talking about but thx for trying.
I'm referring to the fact that the PC will hit a wall of performance that the console will not. Games will continually develop for the console that look steadily better and better while on that PC you dropped $ for nothing will be released that you can play.
Sure if you put any old console up against a much newer PC there isn't going to be a comparison. Of course, being a poor guy myself I'd rather drop $250-400 for a console that will keep cranking out great games for 6 years as opposed to buying a PC for a few thousand that will be unable to run anything and look decent in 1 year...
aznpxdd said:
