Ok im going to try and explain this the best way that I can so I hope I dont loose anyone. I was cleaning my 360 today taking it apart blah blah. I Figured while I was cleaning it I would replace the fans. I got New fans from Xoxide.com so I put them In. I noticed that my 360 is a bit cooler now but still out of the rear is still hot air.
I have a case cooling question for you guys. My 360 is a Falcon 9-9-2009 system. Ok now here is my question. Do you see where I made the Black Arrow? Where there is a Piece of Thin Metal connected to the case itself. Do you thnink If I removed this it would allow more Hot air to Escape from the 360? to me it seems that once you put the system back together all the Metal basicly traps all the heat inside the system.
If you put the case together with that piece of Metal still on it you notice its a Tight Seal where I believe it traps heat but when you dont put it together with that piece on there is a really good amount of space for heat to escape. Im just wondering is this piece of Metal Viable to the 360 is it needed.
This image is not mine found it online so I used it as a Reference.
