Xbox 360 and PC's
Pegesus
Quick question:
Can an xbox 360 be run into a computer and played through the monitors. If so what is needed to do that.
Quick question:
If you have an input on the monitor for a Spare DVI, You can connect to it from the 360's HDMI stright to it. (if your 360 has HDMI)
OR, You can buy a TV input adapter for the PC.
yeah i'm running a componet 360 not HDMI. So all i need is a tuner card then?
