XBMC system with CEC, USB powered?
stenrulz
Hello,
I am currently looking into a XBMC system that supports HDMI CEC, 1080p and turns on and off with the TV ( possibly powered by the TV USB ports). What do you recommend?
Thanks.
I do this with my PI in the bedroom. Not enough power for my livingroom MCPC, but you probably dont care about that when your looking for USB Powered.
Pretty well, I mean, it's not going to be as fast as a full blown HTPC. I'd suggest openelec it's a lightweight xbmc build made for raspberry pi. It's good enough to stream 1080p if you have wired Ethernet.
