X99 Rif Freezing
Hi, my PC is freezing randomly. out of nowhere and the only thing you can do when it happens is shutting down the PC. I'm using it after a fresh windows installation. It might be related to the windows update but I clearly don't have a clue. In fact I feel it's more probably that it happens when I'm not fully utilizing it than when stressed. So I've touched the Power Settings and such , even in Bios with no good result yet. For instance I was able to pull out a full 2:30 hours of AIDA Stress with no issues and it felt like if I could have done for a lot more time too.
Bluescreenviewer doesn't show any dump file either. So if someone can help me, I'll be vaery greatfull, since I'm having my two rgs with issues roght now and I need them to work. Thanlks in advance!
any help? BTW I'm using WIN10 and any tip or idea to try, I'm all ears since my two rigs (this oen and the 1151 8700K) are not working and I actually need at least one for my job
Finally after restarting I've got a BSOD:
Dump File : 110718-12828-01.dmp
Crash Time : 11/7/2018 5:49:57 PM
Bug Check String : MULTIPLE_IRP_COMPLETE_REQUESTS
Bug Check Code : 0x00000044
Parameter 1 : ffffaf82`fcf9a010
Parameter 2 : 00000000`0000121b
Parameter 3 : 00000000`00000000
Parameter 4 : 00000000`00000000
Caused By Driver : CLASSPNP.SYS
Caused By Address : CLASSPNP.SYS+1dc5
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+1a9490
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\110718-12828-01.dmp
Processors Count : 24
Major Version : 15
Minor Version : 17134
Dump File Size : 1,783,892
Dump File Time : 11/7/2018 5:51:15 PM
I've added in a PDF the crash list
  • Crash List BSOD.pdf
I found this by googling classpnp.sys
https://www.chrisnewland.com/solved-windows-7-hang-on-boot-classpnpsys-64
Maybe try changing the SATA controller from AHCI to compatibility mode.
or try this stuff:
https://www.drivereasy.com/knowledge/classpnp-sys-blue-screen-in-windows-10-7-heres-the-fix/
Thanks man, thought those links are more related to not booting (thought yeap, lately I had some BSOD when booting, the next rebbot after all of them initiates windows...and the otehr thing is that both are more WIN7 related and I'm on WIN10, nonetheless I'll try it and see what happens, thanks!
BTW I've ran a software calle "whocrashed" and gave me these results:
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which allows you to perform more thorough and detailed analysis. It also offers a range of additional features such as remote analysis on remote directories and remote computers on the network.
Please note that this version of WhoCrashed is not licensed for use by professional support engineers.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
System Information (local)
Computer name: DESKTOP-L48U3AN
Windows version: Windows 10 , 10.0, build: 17134
Windows dir: C:\Windows
Hardware: All Series, ASUS, ASUSTeK COMPUTER INC., X99-DELUXE
CPU: GenuineIntel Intel(R) Xeon(R) CPU E5-2673 v3 @ 2.40GHz Intel586, level: 6
24 logical processors, active mask: 16777215
RAM: 34267639808 bytes total
Crash Dump Analysis
Crash dumps are enabled on your computer.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Thu 11/8/2018 5:14:13 AM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\110818-12859-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1A9490)
Bugcheck code: 0x44 (0xFFFFB28CD43529D0, 0x121B, 0x0, 0x0)
Error: MULTIPLE_IRP_COMPLETE_REQUESTS
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a driver has tried to requested an IRP be completed that is already complete.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: usbxhci.sys (USBXHCI+0x29BAD)
file path: C:\Windows\system32\drivers\usbxhci.sys
description: USB XHCI Driver
The crash took place in a storage driver or controller driver. Since there is no other responsible driver detected, this could be pointing to a malfunctioning drive or corrupted disk. It's suggested that you run CHKDSK.
On Wed 11/7/2018 5:49:57 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\110718-12828-01.dmp
Bugcheck code: 0x44 (0xFFFFAF82FCF9A010, 0x121B, 0x0, 0x0)
Conclusion
3 crash dumps have been found and analyzed. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
X99
Maybe see if it crashes in safe mode (hopefully it won't) then it would most likely be a driver or service type of software running on your pc. Go to task manager start up tab and disable all there. Last time this happened to me it turned out it was an Asus printer sharing utility that i didn't even remember installing that was the culprit
I've just checked two PSUs and both freezed (both are great BTW, a seasonic 850 Gold and a SF600), so I guess that the PSU being the problem it's out of the question...I have reinstalled windows minutes ago, let's see what happens
Install the latest drivers for your motherboard that you will download from the manufacturers site.
Do the same for your video card.
