Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hi Dan,
Thank you for the suggestion.
I've just read your review about the Mpower dtd. May 29th.
The conclusion was "hard to suggest for purchase" and not a must have. Lastest Bios/Software update have changed your thoughts ? Just to avoid to incur in troubles I prefer to raise the budget.
Please let me know.
Marco
I'm used to Asus mobo, but Sabertooth is very expensive here in Italy. I'm also evaluating the MSI Gaming 7, that matches my colour scheme and it is very similar to the Mpower. I'm checking also Asrock X99X Killer It seems that Asrock has good bios and OC.
