X99 mobo endless options! sub 300$
Henri108
Hi, I need a mobo for a few X99 builds I'm doing.
Budget is under 300€. I'll buy it here:
https://www.alternate.be/Hardware/Moederborden/Intel/Socket-2011-3
I don't need anything on it, It will have 1 GPU, i7-5820K and ram that is supported by the mobo. Will do a light daily OC (4Ghz). I need it to be as stable as possible and not give me problems. I don't care about any other features.
Any help would be highly appreciated!
Currently looking at the MSI X99A SLI Plus because of the pricepoint.
MSI X99A SLI Plus is a solid board that many people have used without issue. It is the board I would most likely choose if going low budget. Next choice would be the ASUS X99-A, but I am not convinced it is worth the extra money
The Asus one is 40€ more than the MSI and the Asus X99A with USB 3.1 is another 20€ on top. Is it also better board than the MSI or is it about the same?
