My first post here and its not a good one...
Ok, just got back from Iraq and had some money to spend so I purchased a DFI Ultra D, A64 3200+, and a OEM Sapphire x850xt this was going to be powered by an OCZ Powerstream 520. Today was the first time I was applying power to the setup. Only one stick of RAM, the video card and the keyboard were plugged into the MB. I used the PCI-Express power connector from the power supply, not the adapter that came with the video card package. Perhaps that was my first mistake. Anyway pushed the power button on the case (Lian Li PC-65)...fans come on, including video card...then the burning and smoke, I couldnt shut it down quick enough not that it would have mattered the damage was done. I do not have the technical knowledge of the x850xt's layout so I will describe what burned. Toward the front end of the card and on the top there are two silver "boxes" about 1/4" wide and about 1/4" tall. This is on the side with the fan, well what burned was on the opposite side, non-fan side. Between the two boxes on the back side is the thing that burned. It looked as bright as one of the LED's from the Ultra D. My question is what might I have done wrong? I RMA'd it back to Newegg along with the Ballistix memory that I was trying to run too. Any help or clues would be appreciated. Thanks in advance.
Mike
Mike
