x850xt fan is LOUD
HowCo
Any one have an idea on how to reduce the fan noise in my new Visiontek Xtasy x850xt pe? During game play the fan noise ramps up and if I tun it down, things heat up. Do I need to buy another card, but which ones are quite? Headsets are another idea but I like my surround sound speakers.
Thanks
I have atitool but the fan needs to run at 50%+ during games and thats when its loud.
My friend has the same card and it has never gotten hot enough to cause the fan to speed up to a point where it was that noisy. My guess is that your ambient room temps are already quite high, and/or you have poor airflow through your case.
By default, my ATI X850XT runs at 18% fan speed until it reaches 80c then shoots up yo 80%. I set about a dozen levels in ATITool and it runs quiet and cool now. :)
Ive installed 4 ArticCoolers so far, all work fine.
If the fan did die.... I'd use it as an excuse to retrofit a nice quiet blowing into the now empty hole where the AC fan was. Meantime it is a good design and quite effective. Sure watercooling would be better but more $$...besides we await Swiftech building a video-STORM block ;-)
The Zalman is better IMO. The Silencer is a cheap POS - the one I bought was defective and the system would not produce video when powered on once it was installed. Changed it out with the Zalman and load temps are now 18c cooler and things actually work.
And yes, I hooked the Silencer up perfectly. It was a POS.
BTW whoever said you probably have bad airflow or really high ambient temps is most likely correct. When I ran the stock cooler it never got hot enough to push the fan over 18%.
I wouldn't trade one large stock cooler for another large after market one. The Zalman is small, effective, and cheap.
i have a question for you all. when its warm in my apt my 850XT PE with idle at 45-47c with 36% fan speed. should i increase my fan speed to say 45-50% when the inside temp is up? because, when the temp in my apt is normal it will run 38-42 with 36% fan speed.
what do you guys use for you fan control settings?
and i have no intrest in swaping out the stock cooler.
Mac.
If it does the job in a case with horrid air flow then it does the job regardless..
AC hater's....oh well.
I'd set the fan to the maximum speed at which the sound doesnt bother you. The stock fan was OK up to 65%, so I just set it to that. But any higher was a jet-engine. SO I switched to AC4rev2. Ive installed 4 of these, all are working fine.
I have encountered ATI issues wiut the CORE SHIM being too high, and have popped it off a couple cards....FK ATI's warranty, this is for HARD people.
