{NG}Fidel said:You can mix and match it from the rumors I have heard. Nothing solid yet, everything from the R3x0 and up is AMR compatible.
I don't want to make you read through the whole thread, but the first six pages are scattered with little tidbits here and there. Unfortunately, the original article at XBit is down right now- I guess their servers are being reinforced after the hacking earlier this week.mavalpha said:Okay, it looks like ATI has thrown a wrench into the works.
Looks like it'll have the same constraints as nV's SLI, so no "upgrading one by one." If you want to go from two XL's to two XT's, you have to dump both and buy both simultaneously. It still remains to be seen what they will require BIOS-wise, but at least now we know how they are taking care of load-balancing.http://www.xbitlabs.com/articles/editorial/display/cebit2005-2.html said:At least for now there is one important update from what was previously reported ATI wants two identical graphics cards to be installed, not two different boards as said before based on information from unofficial sources. Here is what ATI says to its partners:
Multiple ATI RADEON X800 XT boards cooperatively rendering a single frame;
Requires two physical x16 connectors on the mainboard;
Load balancing and synchronization implemented entirely in software;
No physical connector requires between devices;
Currently assumes two identical graphics devices installed in both connectors
The link was already there, just unavailable right now. Unfortunately, even Google's cache doesn't have an accurate version- just a SQL crash (lol). Otherwise I'd link you to that.Unfortunately, the original article at XBit is down right now- I guess their servers are being reinforced after the hacking earlier this week.
Actually, that was just speculation from the same thread I linked above. We weren't sure how they would mix-and-match, and now it looks like they won't.HighTest said:But at the same time, AMR was hyped at being able to mix and match, the important point being that the faster card is reduced in speed and features to match the lower end. So matching an XT850XTPE to a X300 or X600 would "suck".
KrakenGuy said:Hmm... Think of it this way... If you combine 2 different VPU's then the checkerboard effect would look odd cause the better video card will render better then the crappier video card, so the image quality would look really odd.
