X850 XT -- What the heck
SilverSliver
Well...Hmm... Im playing BF2 at stock speeds, and the thing locks up, fan goes silent and then i wait. I get a CTD, click it off, reboot. Starts up into windows and its just a black screen...
Start up into safe mode, uninstall drivers, reboot.
Reinstall drivers, reboot.
Back into windows, black screen.
What in blazes..
edit --
Fixed it...reset my cmos jumper and set CPU back to stock speed.
How would the CPU OC'd have an effect? My agp/pci was locked and was even at stock volts.. Im stumped,will play with it some more.
sounds like a PSU issue, perhaps. I'd check your rails with a multimeter under full load and see how they look.
I had the same issue at first with my 6800GT and my CPU. At mild overclocks of the CPU, the GT could be flashed to an Ultra and run at 435/1200. With the CPU overclocked to greater than 17%, the GPU's core and GDDR3 speeds had to be reduced to avoid artifacts and CTDs.
Even buying a newer and beefier PSU like the Antec NeoPower 480W with active PFC didn't change the situation much. So, I settled on a compromise of 2.8E@3.4ghz and Ultra at 420/1100.
Well, I run the games I want at the settings I want for the most part.
8-12 months from now, hellllloooo dual core AMD's and SLI =)
